Which is the coil that is for #1 cylinder, front or back in relation to the carb? Also the manual says the "flat retainer 'must' be horizontal in relation to the armature plate." The spring of both sets of points is too long for this. Do I have them in wrong or do I have to grind the spring down? I can put the clip on from the top but don't know if that's ok.
Plus a bit confused about my coil test readings. The coils I removed had impedance of 6900 and the new OMC coils both test at 44 and 4500. Product support sent me a link that said anything from 3000 to 8000 is a good coil. I would think the lower resistance would make for better conductivity. but I also think that the higher resistance would create a more powerful spark by creating a delay in the release. Maybe I have it wrong, I'm not a mecho/electrical engineer.
