Evinrude 30hp prop
rhysen
im in need a new prop, my current prop is 10x15 which doesn't like any real weight in the boat. im thinking about a 10 1/8 x 11 aluminum.
Which of these to props would be more suited. my boat is a 4m stessl deep v hull with a 91 evinrude 30 hp
thanks in advance
jestor68
Re: Evinrude 30hp prop
The prop selector says a 12" pitch prop for your application. The 11" pitch would be called for if you were planning to carry extra weight.
If you have access to a tachometer, that would be a help to prop it correctly. The WOT rpm range should be 5000-5500 rpm.
