Hi All,
I'm new on the forum but been reading it for a long time - it helped me a lot but now I need to ask for advice as I have enough and don't know what to do.
Short story:
I have bought old evinrude with several issues (I was thinking that engine is quite ok) and managed to get rid of most of them spending little fortune and a lot of time on reparation. It had very good compression on both cylinders.
Exhaust gasket below engine was blow out, stator was bad, coils and power pack etc.
I have changed this parts:
- new sparks
- new coils and power pack
- new exhaust gasket below motor
- new water pump
- new thermostat and gasket
- new stator and plate (bought used but in good condition)
- cleaned the motor, carb, checked fuel pump
- changed few gaskets - between fuel pump and engine, carb and engine etc.
- checked gas tank, cleaned it and put new gas
- changed fuel line
Most likely I've done more but forgot it already. I've set up carb and timing.
Motor works much better now but still not as it should. With low rpm it is ok but when I want to go faster and throttle starts to open more I'm experiencing most likely misfires - motor starts to shakes regularly and has no power. I can't go to WOT, not even to half open throttle. I've tried to squeeze fuel bulb to check if it caused by fuel pump but still the same. Motor is a bit hot, maybe even too hot - I still can touch the plate with the spark plugs for +/- 2s. It produces a lot of steam and when I start the motor for a first few seconds I can see exhaust fumes going out from water outlet. After few seconds water flows good. I got into conclusion that maybe there is a water going into one of the cylinders at higher rpm and took the exhaust plate out and power head to check the gaskets. All were looking ok in my opinion but the exhaust manifold? looks a bit weird - it is obvious that bottom cylinder produce more carbon muck and also had a white stuff around the lower exhaust port. Cylinders gasket was fine with no signs of bad sealing. Could you please take a look on the attached pictures and share your thoughts? Any ideas what could be wrong with the motor and what should I check and do to finally enjoy fishing?
Best Regards.
Short story:
- new sparks
- new water pump
- changed fuel line
Best Regards.
