Evinrude 3hp folding motor
Status
Not open for further replies.
rickinri
I have a 1966 Evinrude folding motor , with a built in tank , have been told that there was a similar model (3 hp folder)that had an external tank ,could any member shed any light on the subject or guide Me to the information?<br />Thanks
R.Johnson
Re: Evinrude 3hp folding motor
They made a fuel pump kit for that engine. If you look at the right side of the engine block, you will see three holes. The center hole has a flat head screw, with a fiber washer, that's where the fuel pump goes. There is a recess on the right front of the engine for the fuel connector.
DHPMARINE
I don't recal the 'folding 'motors as using an external tank,but the non-folding ones did.They used the same powerhead.<br /><br />Also OMC had 'suitcases' for the folding motors.and the whole thing could go in your trunk.<br /><br />DHP
seastuff1
I am looking for an internal gas tank assembly for a 1966 3hp folding. Can anyone assist or refer? thanks
bikebunky
I had a 70 evenrude folding motor that used an external tank. The motor had a fiberglass hood similar to the 66 johnson 3 hp eng I had. How many years were the folding motors made and are parts available
1946Zephyr
Cool. Another old thread :D
You should have started your own thread. The mods here frown on that. If you look in the "Top Secret Files" in theForum here, you'll see a list of salvage yards. This is a good place to start.
Status
