hy all,<br /><br />i'm looking for a crank for an evinrude. id did soem massive searching on the net (about 3000 ads) but i found nothing. could someone here give me a suggestion?<br /><br />thanks in advance
Used parts dealers should have plenty of them. Try:<br /> http://www.tcoutboard.com/ <br />Marine Parts Outlet<br /> http://www.outboardexchange.com/outboard_parts.htm <br />If you can find your local outboard junkyard, you'll probably get your best deals there. What's wrong with the crank you have? One alternative is to send it to www.neecaprecisions.com .<br />Also, there's this: Ebay Find. <br /><br />PS - I assume we're talking about the crankshaft rather than the pull-start.<br /><br />EDIT: I just noticed we're in Project Boats. This will likely get moved to a more appropriate catagory.
Moving to Evinrude troubles.<br /><br />Paul, please refer posters by organization name rather than link. It seems direct links to commercial sites interfere with iboats business interest in some way.<br /><br />Thanks,
