evinrude 40
rangerracer
hi guys i was wandering if someone could help with a little problem.i have a evinrude 40hp model#40455s i believe its a 1973 anyway i cant get it to run right starts ok but then revs sky high like its full throttle but its not.i thought the butterflys in the carb were open to far so turned them down but still nothing so i took the throttle linkage completly to operate it manulay with no change. any ideas waould be great
ob
Re: evinrude 40
Rangerracer , you sure the flaps you saw shut were throttle flaps and not choke flaps? Don't see anyway it could run wide out with flaps closed down.
rangerracer
Re: evinrude 40
100%positive i cant figure out how fuel was getting in there if the butterflys were all the way closed.
ob
Re: evinrude 40
Sounds like you may have to remove carbs and check for stuck open needle valves.I would still think that engine wide open would only be momentary with air choked off through carb throats.Also, inspect carb base gaskets for seal.Does primer bulb get hard after priming?
Joe Reeves
Re: evinrude 40
Ranger.... Remove the flywheel and check the points. Make sure that they are set at .020 when the keyway on the crankshaft aligns with the fiber portion of the points (the fiber that runs against the cam lobe).<br /><br />Check to make sure that the woodruff key is perfect and is not even the slightest bit worn. If that key is worn even a few thousands, it affects the timing. Also use only the proper key (OMC #307480) as anything else will give you a problem.<br /><br />If the key has ever sheared, causing the c/shaft and flywheel tapers to be damaged, those tapers will require restoring to normal (or close to it). The flywheel nut must absolutely be torqued to 105 foot pounds.<br /><br />While you have the flywheel off, check and make sure that the timer base armature plate (the plate the points are mounted on) moves freely, doesn't stick, isn't jammed, and that you can obtain full retarded spark advance.
StAugVol
Re: evinrude 40
RangerRacer,<br />I have the same problem with my Evinrude 115. What was the fix for your 40?<br /><br />Thanks
