As the title says a 40hp Evinrude -1990 (E40EESR).
last summer I noticed that the reversed worked but "jumped" a bit when I pulled the throttle.
Now last week I was going to launch the boat and test drive, forwards it went well, but backwards I got nowhere.
So I picked up the boat and started googling and looking around a bit for help. Took the gear housing apart and thought I would measure the gear pin how long it was as I read that this could matter, but I can't find any information at all regarding my engine. The numbers I find there is no way I can adjust the pin to (404mm) for a short, and the closest I get is 425mm if I thread the pin in the bottom.
Finally found a guy who mentioned 429-431mm (check attached pictures), but according to my book it should be 404mm or 531mm?..
I'm a little bit aware that it could be the clutch dog that is bad, so that will probably be the next step in case this doesn't work, but would be grateful for all the help I can get before you take it upon yourself to tear apart the entire gearbox!
