Crownline230
- Feb 22, 2013
- 36
Hi all! Just got this clean new to me 1990 Evinrude 50 that has a cooling problem. I dried the lower unit and the grommet between the water pump and water riser leg(if that’s what it’s called) was deformed, so I ordered a water pump kit. I positioned the grommet and held a hose to it to check the water flow and water started coming out of two holes from the inside leg as evident in the photo. Water isn’t coming out of the pee hole and when it seems to fill water comes gushing back down. Is this normal or do I got a problem to solve? Thanks in advance for any input and suggestions!
