evinrude 60 heat and oil sensor locations
kyfisherman
Does anyone know where the temperature and oil sensors are located on a 91 Evinrude 60 horse? I am having problems and have about narrowed it down to a sensor gone bad. What color of wire runs to each sensor?
angus63
Re: evinrude 60 heat and oil sensor locations
Temp warning sensors are in the head (tan wire). Oil sensors are on or near the vro (oil flow) and in the oil tank (oil level). Not sure of the colors there, but should be obvious with a look see. A manual is a must if you plan to do your own troubleshootin'!!
