I have cleaned and adjusted carbs, performed link n sync, adjusted ignition with a timeing light at the flyweel, installed new QL77JC4 plugs, new gazolin, new fuelhoses and handpump, new VRO-oilhose and handpump, new power pack, new alarmsystem (horn, wirers and alarm-lamp.)<br />But when we started it up, it runs great up to 2500 rpm (in gear and without on gear). But at apx. 2600 rpm (in gear and without in gear) the motor starts to shake, cough and spit, just like if the primer solenoid was pumping fuel in the motor. And never mind how mutch power I give the motor, it will not give me more than 2600 rpm. The shakeing, coughing and spitting are gone again, when I take it back to 2500 rpm.<br />I have tryid to disconnect all TAN wirers, but it did not help. ( I have put the TAN wirers back again)<br />The comp. on the cyl. are 112, 115 and 116 psi. And Im quit sure, that it is an ignition problem, since the problems starts at 2600 rpm in gear or in neutral.<br />What have I overlooked ??????????????????<br />Does anybody know, what can be wrong ?
