Re: Evinrude 60HP VRO 1990 temp.
"The servicebulletin according to outlet of cooling-water to the pea-hole from the top of the motor, hase been done."<br /><br />I've done the same on my '86 70 horse Johnson. Since then, I've noticed an increase in temp at the telltale hose that I didn't have when the water came out of the original outlet on the lower side of the exhaust cover. It's not burning hot, just warmed up pretty well. I attributed the temp increase to the fact that the water is now coming out of the exhaust cover thus warming some. At idle, I can touch the thermostat and block without burning myself and at idle on the muffs, water isn't coming out of the exhaust ports (my hand will get wet if I hold it over the ports). BTW- My old thermostat would let water through the ports at idle.
