Evinrude 60hp
Taz59
UK Calling,just purchased a speed boat with a Evinrude 60hp I got it for a bargain the guy just wanted it of his driveway,the only problem is that<br />it needs a new water pump and new piston rings,what sort of job is to replace these parts,and can you bye manuals for it.<br />Thanks,
JB
Re: Evinrude 60hp
Howdy, MD.<br /><br />There have been at least three completely different 60hp Evinrudes.<br /><br />To be of any help to you we must have the model number.<br /><br />Water pump overhaul is a pretty routine job if you have the correct manual.<br /><br />Why do you believe that it needs new rings?<br /><br />Let us know. :)
Taz59
Re: Evinrude 60hp
Hi JB,<br />I pick the boat up later today, its 3.30am I am on nights at the moment, the guy bought the boat last year with a faulty engine the guy he bought it of told him what was needed to get the engine running, but he has not had the time to repair it.<br />Iam working Saturday night so I will get in touch,<br />Thanks for the reply, I love this site
JB
Re: Evinrude 60hp
Could be one of those "Change stuff until it starts to work" wrenches.<br /><br />Get the engine. Then we'll troubleshoot it and see if it really needs rings. The first thing you need to do is a compression test.<br /><br />Meanwhile, we still need a model number so you can get yourself the correct manual and we can give you correct advice.
Taz59
Re: Evinrude 60hp
Hi Guys ,thanks for the reply,I picked the boat up today,the engine is all stripped down and it does need a new piston and rings, I have been looking for the serial No but can't find it,what info do you need to find out what year and type of engine it is, I have took some diamension for you piston 80.40mm their is NUMBER on the block <br />326100 also stamped on a what looks like a core plug NUMBER E60ELCIA also on each carb their is a Number 3962291A 60L MX 5LJ Number 396290A 60MX 5JJ<br />I am on nights and I have brought the engine into work to clean it up,let me know if you need any more info.
boatingfool
Re: Evinrude 60hp
Hey Muffdiver,<br />I dont have much input except that I love your screen name!! :D
rterrian
Re: Evinrude 60hp
Muffdiver,<br /><br /> That number, E60ELCIA, is your model, Thats the number you need to order parts. That number shows it is A 60hp, Electric start, long shaft, 1981 Evinrude outboard.
Taz59
Re: Evinrude 60hp
Cheers Guys, just took the piston out it has a 1/2 inch hole in the side of it and the remanes of it are splattered on the liner walls, how has this happened : :confused: :confused: can you recomend a good Manual for this engine.
steelespike
Re: Evinrude 60hp
MD,I come up with 1981 2cylinder. 3.187 inch bore.<br /> pistons and rings are available in std,.020,<br /> .030.Same parts fit 80-85. probably harder to find over there but a good dealer may be able to help.<br /> Perhaps you can find someone on line that will ship over there.
steelespike
Re: Evinrude 60hp
Best manual would be factory manual.You may be able to find on ebay or at www.kencook.com<br /> They do reprints of originals.Dont know if they ship oveseas.Second choice would be Celoc or Clymers and there are some others.<br /> Manuals are at the bottom of this page,<br />Amazon.com and again ebay among others.
Taz59
Re: Evinrude 60hp
Hi Guys,<br />What type of threads are used on Evinrude engine,<br />metric or imperial, where are Evinrude Engines Manufactured,still having problems locating a suplier for a repair manual,<br />Thanks
Taz59
Re: Evinrude 60hp
Taz59
Re: Evinrude 60hp
Hi Guys,<br />How much would it cost in the US to bye two pistons and rings for a evinrude 60hp 1981, i don't know what it is like in the States but over here you mension anything to do with marine engines and they add three zero's to the end of everything,<br />Thanks
Taz59
Re: Evinrude 60hp
What cleaning fluid should I use to clean my carbs,and how far should I strip them down,and do I leave them to soak,<br />Thanks, <br />I love this site,
Taz59
Re: Evinrude 60hp
