Re: Evinrude 6hp Alternator
Hi Larry,<br /> Yes, there was (is?) an alternator available for your motor. You'd need the stator, up under the flywheel, the rectifier, the wire block, and the battery cable. I believe these are all available through your local Johnrude dealer. Alternatively, you might find similar parts on junked motor if you have a motor graveyard nearby.... Most of the "Sail Master" 6 and 8hp models had the charging system as standard issue. I don't think it was a very beefy charging system, only a few amps, but enough to keep the battery topped off for lights, etc.<br />- Scott
