Evinrude 70 bad high frequency vibration
Sashap
New prop been using for a few weeks. All ok until today. Such a bad vibration screws coming loose on boat and engine. Most noticeable at wot. No loss of power. Not like an engine misfire vibration but like someone installed a jack hammer. What causes this all of a sudden? Didn't hit anything. Prop still perfect. All bolts were tightened recently. Tried different prop but didn't notice change. Help please?
flyingscott
Usually when that happens something bent like driveshaft/propshaft or broken motor mounts. Could also be a bad bearing somewhere. Not an easy problem to guess at
Sashap
Could it be internal engine damage? I ran it almost an hour before I realized it was happening
flyingscott
Yes it could be you will have to do some diagnosing could be an electrical issue need year and model #
Sashap
1985 long shaft with power trim
Sorry serial not handy
Chinewalker
Check the upper bearing - grab the flywheel and see if it moves laterally.
Check the propshaft for straightness - spin the prop in neutral and watch the dimple in the tip of the propshaft. If it wobbles around, the propshaft is bent.
