I recently purchased a boat with a 1974 evinrude 70hp hustler motor. The motor is appears to be in excellent shape. I have started it but in water when put in gear, it stalls and dies. when out of water it will rev up in gear. It was winterized so i do not think that old gas gummed up the carbs. i have changed all plugs and it seems to firing on all 3 cyls. It does have a melted rubber type of goo running down from the stator. Some one told me this meant the stator was bad. Will this cause this type of problem?
