Re: Evinrude 9.9HP 4 stroke
OK,remember you asked for it:
April.1997
The very first day I took my brand new boat out for a test run after about one hour the motor started to cut out. It would start up and run for a few minutes and this time became shorter as I headed back to my port. I barely made it back. I took the 114lb motor off which is a nasty job while the boat is in the water. It was back at the shop for a couple of weeks.
June 14,1997
They replaced the electronic power unit at no cost to me.
No problems during 1998
May 1999
Motor would not start so I again returned it to the dealer
July 5,1999
Replaced the power unit again, at no cost.
Near the end of the 1999 season the motor started stalling again when ever it ran over 1/2 hour.
Took back and they once again replaced the power unit
Early in 2000 it started to stall again. I noticed oil running down the side of the motor. After 9 weeks at the dealer The fuel pump and rectifier were replaced at the cost to me $254
After the rebuilt fuel pump the motor started slowing down and I could get in back up to speed my pumping the bulb on the gas line. I lived with this till the end of the season but when it continued the next year I took the fuel pump out and found that they had put the diaphragm in backwards. Correcting this didn't solve the problem. I purchased a new fuel and the problem went away. Don't know what the dealer did to screw up the original fuel pump
I also had to replace the water power twice and I am currently waiting for a repair kit to fix the fuel pump again.
I also replaced the stator and a power pack again recently. I can't find my notes for the date of these replacements but I think by now you get the idea. I realize water pumps and fuel pumps have to be replaced but this motor is seldom used because it is on a sailboat and only turned on to get out and into my slip. When it runs its a great motor but I am a fraid to take long trips because I never know when the power pack will blow again. I bet in the 12 years I have had this motor it probably hasn't run more than most motors run in a year or two
