Evinrude 90 Ficht 1998
Status
Not open for further replies.
Roger01
Hi all when the engine reaches 4000 rpm a rev limiter kicks in and red ! Sign comes up it then goes into limp mode , engine has always run fine , any ideas ??? Thanks in advance
Norway 82
Hi. Did you solve your problem? I've got the same problem with my Ficht 90hp 2003 model. Goes into limp mode around 4000 rpm's showing high temp. Have changed stats and waterpump.
Jim Lurvey
Norway 82
I have same issues, same motor. Did you ever figure out the overheating problem? .
Status
