How do you remove the lower housing in order to check or replace the water pump. I understand that there are 5 bolts to remove. How do remove the gear linkages. What else is there to loosen or remove. Does the whole housing then just drop or do you have to slide it off? Does anyone have any schematics or procedures. <br /><br />Also for reinstalling, are there any special requirements (grease, sealant, etc)<br /><br />thanks<br />len
