1978 Evinrude 70hp
Hello
My motor has decided to start acting up. It will run good up to about 1/3 throttle then lose power and die. Will restart right away and idle all day. Also starts well cold. Here's what I've done/looked at so far: cleaned carbs completely, they didn't look too bad actually - adjusted carb and choke linkage to service manual specs - gas and oil were fresh at 50:1 - pulled fuel pump and it looked fine - plugs looked ok but I changed them anyway, they were Champions, put in NGK's which did help it start and idle better, but made no difference at 1/3 throttle - checked compression, 120 psi on two uppers, 112 on lower - nice blue spark will arch 5/8" on adjustable checker while turning it over, used an inline spark checker while on the water and still had spark as the motor died, just don't know how good of a spark - checked all of the connections at the power pack and other harness locations - pulled the flywheel and checked for loose connections/signs of shorts - According to the service manual I need a special tool to check the power pack which I don't have. Are there any good tests the average joe can do to test the power pack, stator, etc? Are there any other possibilities you guys can think of? I've exhausted my 2-stroke knowledge and would sure like to have it running again by the long weekend!
Thanks in advance for any ideas!
Ray
Hello
Ray
