Ok i just found out the kill-switch is making probs. Dusconnected the main plug and jump started it,and it started right up. Can i just cut the two leaders going onto the kill-switch?
Key switch is new,and was also used in previous control box.i cut the one to kill switch and motor runs great. But when stopping it,it must be primed,its ok,not a prob. Many thanks for helping me out once again,you guys are awsom
It does not stop on choke when warm,i had to disconnect fuelhose,even then it run long after. I can use a regular on and off switch to replace the original kill switch right?
you have a ground issue. the key switch should ground out your powerpack when you switch it off. you can use a toggle switch but it sounds like you clipped the wrong wire somewhere.
