evinrude be120tlco
Dali30
Got this motor yesterday.between cylinders there is a black box shaped as powerpack,but inside there are two relays and some connecting spots. This motor came with a harness to this box,with 6 leaders total. Colors are,blue with white stripe,green w/white stripe,red w/white stripe,black w/brown stripe,yellow orange w/light brown stripe. Where do i connect these wires?
175se
That's the trim/tilt box, cant place the last wire color. Go to the stickey files up top here it will tell you the harness.
Dali30
Ok thats what it is. Thanks ill take look in the sticky section.
V153
There should be a connector from the control box.
The red, green, blue connect to the trim switch in the control lever. Other two are for the trim gauge/sending unit.
V153
There should also be a green and a blue wire connected to the trim motor.
Dali30
Green blue and red is connected,tilt and trim are working as it should now,thanks for helping with that. But now i cant get the damn thing to start.
