evinrude,bubble machine
slowpoke
My 15hp,74?motor is blowing air bubbles from the lower unit when I rev the engine in the test barrel.Getting very little water from exhaust holes.I ran it for 2or3 min.and it was still cool enough to lay hand on motor block.Need pump?if so how do I go at it?thanks for the help.
oldboat1
Re: evinrude,bubble machine
It's thru-hub exhaust, with most of the water going out under water (with all the bubbles). If the head is cool/warm to the touch, the pump is working.
