I have a 1972, 50hp Evinrude Electric shift that I am in the process of replacing the wire harness and upper seals. Tonight I removed the soldnoid cover, to pull the old wire out and brought to light several questions. I do have the service manual for reference. When you pull the cover off there is the wave washer, with a green grease smeared all over it, is it necessary to replinish this? Does it matter, which way the wave washer is placed? If so, what type of grease is it? The upper solidnoid pulled out when removing the wire, I just pushed it back in? Will this cause problems, in the manual it says to make sure plunge rod is even with top of solidnoid? While it looks flush, I am not positive. Are the measurements mentioned in the manual only if removing and rebuilding the lower unit?
As far as the upper oil seal (bearing housing), is there a way to remove this without the OMC special tool. It looks as if this bearing is pressed in and must be removed in order to replace this seal.
The reason for replacing cable is it was cut and cracked and had water in the lower unit. Does anybody that works with these engines know where it is prone to leak. I did a pressure test and could not find/or hear leak. I think it was leaking from the cable. I apologize for the long question, I am a little nervous about this lower unit because it is electric shift and I am not very familiar with the insides. Any advice would be appreciated.
Thanks
Tex
Thanks
Tex
