EVINRUDE FICHT 250 HP / 2003 - "NO OIL" ALARM - Please Help
hydrasports03
I own a 28 ft with twin 250 evinrudes and my starboard motor lit no oil so I looked at it and could not find out why there was no oil getting to the motor. I decided to pull open a small panel on the left side of the motor to find a slot marked spare fuse empty then pulled the top fuse to find it blown! How can I find out if the injector is the original and what could be blowing the fuse? I put in a new fuse and it popped as soon as i brought up the RPM's. I checked the oil pump and it is giving adequite flow of oil. Please help.
jonesg
Re: EVINRUDE FICHT 250 HP / 2003 - "NO OIL" ALARM - Please Help
Might want to have the codes read, or get the software and cable from ebay and diy.
Maybe the injector needs rebuilding.
boobie
When you say good oil flow, are you talking about the oil lift pump ? If you pulled the upper left hand fuse in the PDP and that blew again that fuse goes to the oil injector. The injector also has a pressure switch on it to indicate no oil. You may have a bad oil injector. Take it where you can get a computer read out on it and see what kind of codes come up.
