Re: evinrude lower unit
OK I just put the parts/scmehematic for each up on two different screens,You may want to go to BPR site and print out each standard drive and the weedless lowers look close as they have different bolt patterns.standard bolts on with two bolts front and rear.The Weedless bolts on with it looks as though 4 bolts 2 on the sides.Both 5 inch extensions are shaped differently,but both exhaust housings are the same.I'd suggest bringing the motor, to the lower you want to buy and compare.Both lowers on BPRs site are so different comparison is your best bet.
