evinrude power pack
largey
HI Everyone,I have a 1977 evinrude 85hp motor that has burned out two packs in as many years.It just dropped spark in one cyl both times.I do not know if they where the same cyl. both times.The motor has even comp. in all cyls,around 120 and runs good .The packs are after market(seirra) THANKS FOR YOUR REPLY.
clanton
Re: evinrude power pack
If the pack failed inless then 1 year, look on pack for the name RAPAIR they will replace the pack if it failed in a year, if you have invoice. Maby.
Dhadley
Sierra should stand behind their pack but you may have to get your dealer to prod them. I would suggest one from Rapair (CDI). Double check your grounds while you're at it. <br /><br />Good luck!
