Evinrude Prop
jmwsd
I have a 90hp Evinrude Ficht. Does anybody know of a good brand of prop to run on this motor. I currently have a 14x11 on a 20ft pontoon. This size and pitch seems to be working fine with the RPMs in the correct range. I am just looking for a second prop that is a 3 blade aluminum. Also does the spline count matter when purchasing a prop?
tashasdaddy
Re: Evinrude Prop
click evinrude props at the top of this page, and order the same prop you have. it has proven to work. yes spline count matters or it won't fit. the link above will ask which motor you have and put you to the right ones.
