cookiesareyummy
- Apr 29, 2010
- 67
1995 E175EXEOM
The engine will run for about 10 or 15 seconds or so then will stall out. When it stalls it slowly drops rpms like it is running out of fuel. I can keep it running with the choke(primer) if I want. So far I have done a ton of stuff to the engine.
I have had the carbs cleaned out by a outboard shop who said used all new needles and floats, spark plugs were changed, the vapor pump (small box shaped fuel pump) was changed, the vro was changed, I ran it on a separate tank with a new primer bulb, so far nothing has changed at all. These carbs don't have any sort of idle fuel adjustment on them so I can't change the amount of fuel going to them. Any ideas on what I should do?
