Evinrude starting problems!
Thermodude
Well it seems I may have jinxed myself by saying that my spitfire runs great with no problems! On a recent trip to the lake after the initial run to my favorite early morning spot, when I went to neutral the engine died.........no big deal. I went to restart and it did nothing......it didnt click, it made no sound at all. After checking all the connections out and finding no problem I moved the throttle/shifter handle into reverse and then back to neutral.................it started fine after that. Three or four more times that day it did this and after messing with the throttle/ shifter positon a little it would start fine. Im sure that somewhere there is a positoning switch that I should be checking out.................can someone tell me where I should start my search? Its a 92 150 spitfire.......................any help would be great!
D
DJ
Guest
Re: Evinrude starting problems!
Thermo,<br /><br />The "nuetral safety" switch is in the control box. Not difficult. Just be sure to take it apart carefully.
Thermodude
Thanks for the help, Im planning on looking into the problem tomarrow!......................
