Evinrude te60tlene 92 60hp miss
Chrisham
buddy of mine is having problems with this motor.cleaned carbs new fuel tried 2 different tanks took coils off running motor no different compression 98 96 92 new plugs could this need a head gasket this compression seems low with my guage
flyingscott
Get different gauge to double check. That compression is horrible. Of.the second gauge reads the same.pull the head
Chrisham
We are going to pull the head must be scored cylinders could the head gasket be the culprit also
boobie
Do a cylinder drop test on it to see which cylinder is bad..
flyingscott
I would usually agree with boobie but not this time. Your compression is bad enough to look at that first. Yes a head gasket can fail.but usually not on all 3. Time to pull the head.
Chrisham
Is this running it with . Plug wire removed.what would cause this low a compression on all cylinders just a wore out motor
flyingscott
Do.you have all the plugs out when you are doing a compression test. could be anything a bad gauge, bad head gasket or motor not turning fast enough. Or the motor is worn out I am not there. A head gasket costs around $20 cheap enough for a look see.
Chrisham
Definitely going to pull the head . when checking compression I just pull one plug at a time.Isnt this how you are supposed to check it
flyingscott
No you pull all the plugs out for a compression test. You need it to spin as fast as possible. Pull the safety lanyard off to kill spark and run another test with all the plugs out.
boobie
Maybe I missed it, but how's this thing run ? What's the complaint ??
Chrisham
Checked compression with kill switch pulled and all plugs removed 109 top 96 middle 92 bottom time to pull head
Chrisham
my buddy took the head off today.He said cylinders looked good,no scoring.He said head gasket did not look blower around the cylinders.There were some disruptions around the water jackets but I don't see where this would effect anything.I am not sure he or I know what to look for.The only scored cylinders I have seen were on a chainsaw and it was obvious.
Chrisham
Took the head gasket to the local marine mechanic.He said sounded like a fuel issue.he said check for an ignition miss with a timing light
