Evinrude tilt trim
RC Wilkins
I have a 96 Evinrude 88hp.The tilt will not go down.The pump motor is running and I have checked the oil level and it is full.The pump motor makes the same sound as if it was at the full bottom position.The tilt did go up and is at full up position
Jmorrell588
Re: Evinrude tilt trim
Bob, it appears that you may have a bad relay. You have Two relays, one for up and one for down. <br /> Take the top off the motor and walk behind the motor. At the back of the motor, you will see a black box. Inside that box is where you will find the relay. Take the cover off the box and swap the relays so that you can determine which one is bad. Once you have found out which one is bad, take that relay out and go to your local dealer and ask for a same kind of relay and install it just like you took it out. It does not cost much to replace this relay and you are back in busines.<br /><br /> Jmorrell
RC Wilkins
Jmorrel<br />would the pump motor still run if the problem is the relay<br />Thanks
