evinrude trim gauge wires
mrimike
i purchased a used 98 johnson 200 and the boat i want to put it on has a trim gauge on it. What wires should be connected? Any color code i should look for?
Chris1956
Re: evinrude trim gauge wires
The PTT Gauge is located inside the transom bracket. It is a rheostat, that provides a variable resistance to ground. The connections are black (ground) and another color (I forget), but you should see the open bullet connector near the PTT wiring harness.
