evinrude trim motor replace 150 1979
felkerjohn
:) How to remove trim motor from engine? Are there bolts on the back side of the trim motor between the pump and the engine bracket? I cannot reach the third screw on the back side of the pump. I have the engine up. I have un bolted the lift arm from the bottom of the motor. I have removed 2 screws on each side of the power trim assembley. What is next? 1979, 150 evinrude.
Thanks for any help with this.
fishfeatures
Re: evinrude trim motor replace 150 1979
couldn't remove that 3rd screw either, ended up having to take the motor off to get at it when replacing a worn out motor..
Will Bark
Not sure about your engine but on mine I removed the four bolts going thru the transom brackets (two on each side) and simply removed the whole trim unit. Put unit in a vise to remove and replace the trim motor. I xcut the blue/white wires to remove since the new moter came with the wires attached. Hope your motor is similar. Good luck.
