Re: Evinrude troller problems
Took a fast look throught my manual and this is what is says under the heading "ELECTRIC MOTOOR SERVICE", "Remove the drive end head from the motor, Disgard the O-rings(2) from the head assemblybut keep the fiber spacer. (you need to get new Oring seals) If the bearing in the drive head end is worn or damaged, replace the assembly." I have not had to pull mine so have not seen the inside of one, but it would appear from the manual that the bearing is a permently attached inside the drive end head and cannot be replaced seperately. There is a cross section diagram of the drive end head in the manual and it appears to confirm this. I can scan this and fire you off a copy if you think it would help.
