Evinrude Trolling Motor
FishRon
I recently acquired a Ranger 360V with an Evinrude Model BHL4TW.99 trolling motor. Since acquiring I have been trying to secure an Operators Manual on this unit without any success. Is anyone out there able to help? Thanks
wiretwister
Re: Evinrude Trolling Motor
I to have been looking for the same......hope someone answers this.
Wire
Silvertip
What is special about this particular motor that you need an operators for. Unless it has an autopilot or similar feature, you plug it in, set the speed and step on the pedal to go. If it has a MOM (momentary) and CONT (continuous) switch, they are pretty self explanatory. Setting the switch to MOM means you need to step on the "go" button to make the motor run. If you set the switch to CONT the motor will run continuously at whatever speed you have selected without stepping on the "go" button.
