Busted Knuckles
- Nov 7, 2002
- 8
Howdy, new here.<br /><br />Lotsa questions.<br />My Dad has a 35 hp Evinrude, Mdl. #35902A, S/N E0001309, but I don't know what year it is, <br />so I don't know what maual to buy.<br />I'm having a couple of problems with it. First of all, it has a really bad backfiring problem. <br />Should I be looking at the points and condenser, the carb, or is maybe the reed valves?<br />Also, is there an electronic alternative available to get rid of the points?<br /><br />The other big problem is the lower unit. Last year my dad had the lower unit replaced <br />because the old one went south (bad seals/no lube). Now the one the shop put on there<br />seems to have a lot of fwd/aft end play, about .165". Is this normal?<br />Also, the shifter has a lot of play. When I tried to adjust it, I found that there doesn't seem <br />to be enough travel it the cable and shifter to properly engage the fwd or reverse gears. <br />I looked under the inspection plate in the middle case and that seems to be OK, so <br />whatever is worn is in the lower unit. <br />Also, the lower unit doesn't split down the middle like my old 18 hp, so I'm assuming<br />there's some magic trick to get it out of the housing, right?<br />Any help would be greatly appreciated.
