Re: Evinrude Water pump kit
Thanks again Tashasdaddy and yes I found the numbers for the kit here but does what I am describing it is doing sound normal or should I replace it and if so just the impeller or the whole works.They do not list a kit with the housing included just the two seals,the wear plate and the 4 new bolts and the impeller.Do I need to find the new housing too?I really do not want to replace anything if it is not bad...
