evinrude wire harness HELP
jeremy5780
i have an 90 hp 1998 evinrude cross flow it has the new wire harness with the three black plugs instead of the red one. my control box has the red plug. I have the adapters for the three black plugs with a pigtail of wire coming off but someone cut the red plug so i cant just connect them so i cut the red plug off my controll box side and i am gonna connect the wires. I have all the same colors from my controll box that i have on my motor harness except my motor harness has a brown or tan with an orange stripe and i cant find this in the book. also there is a black with white stripe on my motor harness, the book says this is stop 2 (ground side) but i dont have this color on my control box harness? these are the colors i have on my controll box harness puprle,purle/white,yellow/red,black,grey,red/purple,brown,black/yellow. I have all the same colors on my motor harness plus the two i mentioned above!
Chris1956
Re: evinrude wire harness HELP
Trace the two wires and see where they go. The sound like they are part of the Quick start feature. Do you have a OEM manual for the motor? if not, you should pick one up. Are you sure that is a crossflow motor?
