Evinrude Yachtwin
Reel Appeal
Hello,<br /> I'am trying to locate two replacement coils and an impeller for a yachtwin 2cyl.Model#3533A Ser.#B5830(Belgium).Any other info like year and hp.will be appreciated as well.Thanks! :)
Joe Reeves
Re: Evinrude Yachtwin
Reel..... You have a 1965 3hp Evinrude.<br /><br />The OMC original and superceeded part numbers for the items you need are as follows (I don't have any of them).<br /><br />Coil - Original #580416 - 582370 - 582931 - 582995 - Latest #584477<br /><br />Impeller - Original #277181 - Latest #434424<br /><br />It's better to install the complete water pump kit which is OMC #379770<br /><br />Should a dealer have the part(s) by one of their older numbers, that's fine as they will work perfectly with your engine.
Reel Appeal
Thank you Joe for the info.I took this project on for a client of mine :rolleyes: .I just freed it today as it was frozen up solid.(PB Blaster in the cylinders overnight/wrench on flywheel nut).The motor has no spark.I have never seen coils this deteorated(cracked open w/corrosion).I'm thinking it may have been submerged for a short time :confused: Thanks again....
