excessive fuel pressure
swampy2646
i have 5.7 merc. q-jet, mechanical, dual tanks with a T type crossover. rebuilt carb. new fuel pump. after figuring out my ignition problem i'm starting a new thread on my pre-existing flooding problem that happend the same time as the ign. problem. after starting, about 30 seconds of running ,gas starts pouring out of the top of carb. upon shutting her down i can hear the pressure and see the fuel still pouring down the carb. i swapped out carbs with same results. problem also happend with old fuel pump. i can somewhat regulate it by just cracking the T a little bit to allow less gas to the pump. i checked the tank vents and they are ok . where is all this pressure coming from? i also brought carb back to shop and it was tested at 10 psi and it held.. any ideas???? thanks Pete
Re: excessive fuel pressure
Ayuh,... Install a fuel pressure gauge, after the fuelpump,+ Check it.... 5 to 7psi is what you Should see...
swampy2646
im assuming its gonna be high, if thats the case, what next??
Ayuh,... It might mean you have a Bad fuelpump I guess...
John_S
FWIW: Last season I had a similiar issue (only at idle and not as much fuel) and installed a gauge and it was over spec at 9-10psi. Purchased a regulator for this season, but didn't install. Fuel pump died, didn't pump at all, this season. Replaced with new pump. No issues at idle, but I didn't reinstall gauge to check pressure.
swampy2646
how can i have 2 bad fuel pumps and 2 bad carbs. is that possible???? john s.....you mentioned a regulator, i have a mechanical pump....... also you have to get pretty creative to splice in a fuel pressure gauge with steel fuel lines.
swampy2646
yeah... i shoud'a went with siera one instead of the quicksilver. i probally wouldn't be twisting my body like a contortionst for the third time, and i would be 40 dollars richer!!!
John_S
I have a mechanical as well. I have a tubing cutter, tubing bender, and flaring tool, that along with the fittings shouldn't have been hard. The regulator I purchased doesn't have any stamping for CG approval, but not 100% sure it is required on it. I will hook my gauge back up and if psi is within spec, won't bother with the regulator. I used a short tubing piece from the pump, along with a temp rubber fuel line and Tee to do pressure reading.
swampy2646
ok, so i did a fuel flow test, the thing pumped 1/2 gallon in about 10 seconds, which is about 10 times more than it should have!!! this probally means the pressure is too high also??? correct??? its a brand new pump.
Apollo75
This isn't a High Performance Carter fuel pump or equivalent is it :eek:
You need a Viton needle and seat --- a new float --- :rolleyes:
Keep those keys in your pocket until you check fuel pressure :)
Have Fun
OFM
swampy2646
thanks apollo, im gonna rig something up for that. but does that mean the excessive flow is irrevelant, and could not cause my problem??
Apollo75
Volume means little as long as it is enough for those two Q-jets your feeding :D
Vroom, vroom :p
As long as the volume is above specifications ---- okay --- could be a pressure relief problem in the pump --- check first -- I have good luck with Viton needle and seats and always change the float when the carb top needs to come off.
I wish you well and will help when I think I can :)
OFM
JustJason
post your engine serial number and the part number of the fuel pump thats on the box.
swampy2646
the part # on the box is 861678A1 i re did the engine with a new long block it was orig. a 1991 5.7 mercruiser 4 barrel Q-jet,
JustJason
well thats the part number for a fuel pump for a 305/350 so it should work. Unless somehow the wrong pump got in the box, uncommon but it happens. Are all of your fuel lines, starting from the tank, ending with the steel line at the carb 3/8ths ID?
Are all the barbs 3/8th ID?
Could still be a defective pump... it happens. 1/2 gallon in 10 seconds off cranking is an awefull lot.
swampy2646
yeah jason every thing checks out, im gonna do pressure test tomorrow and hopefully get to the bottom of this. thanks, pete
swampy2646
problem solved!!!! did the pressure test on the brand new fuel pump, 21psi !!!!!!!!!!!!!!!!! put the old one in, runs fine. now comes the part that sucks, my friend at the parts store told me (on the cuff) that he had taken back 4 or 5 pumps for the same reason!!! quicksilver screwed the pooch somewhere. Thanks to all for your help. Pete
