My 1989 Evenrude 9.9 2 stroke always has an excessive amount of oil on the plugs. Just changed the reed valves and still has a slight "popping" sound at idle. Installed a 15hp carb and Boyeson two stage reeds and still pops a little at idle.Only ran it with the muffs but will try it out in water in the morning. Would too much oil in the fuel cause the popping and plug fouling? Tried adjusting the slow speed knob but no change. What else???? Compression in both cylinders is 110psi,carb was rebuilt before installing and the reed plate was machined before using. What else can be done? HELP!!!!!
