Excessive Smoke and Oil Depleting Fast - 1996 Johnson 25 HP Outboard
GizmoFelix
Hello,
I have a 1996 Johnson 25 HP outboard which has recently begun smoking (gray or blueish, not black) especially at lower speeds and the oil seems to be draining quite quickly. I filled up the oil reserve to full and almost half of it is gone after about 6-8 hours of trolling. I am suspicious the motor is burning more oil than it needs to, but unsure how to fix this problem. Any thoughts?
Thanks in advance,
The tank and the mixer are to be taken off.-----Then throw that unit away as far as you can.....They are deemed unreliable and you are lucky you have not ruined a fine motor.------Mix fuel at 50:1 and enjoy that motor.
