About a month ago I took it out of the bay and removed the four drain plugs on the 4.3L (mine is a 1990 model year),
Today I went and stuck a pick inside the drain holes and broke though rust causing all the water to come out from each manifold so they were plugged as they often are. . The block was dry. I removed the water inlet hose from the bottoom of each manifold and one was completley clogged with rust, had to dig it out with a screwdriver. I dont think this happened overnight, but I ran the boat all last season presumably with this water inlet clogged. The upper water inlet for the riser was not clogged. Everything still seems fine,, but now I am wondering what kind of damage may have been caused by this being plugged up? Im thinking of filling it with automotive antifreeze this year just for the corrosion protection, making sure to wash it out before I get on the lake next spring.
