Exhaust alarm fitting?
Simoniz
I want to put an exhaust temperature alarm on my boat which has a Mercruiser 3,0l inboard engine.
Rather than buy a kit, Ive bought a temperature controlled switch and a buzzer and I need to fix the temp switch to the exhaust downpipe. I was planning to fix the switch to the downpipe (just below the rubber coupler that connects the downpipe to the riser) using a couple of jubilee clips but the switch has 2 lugs on it with holes so that it cam be screwed or bolted to a surface.
Im now thinking of drilling 2 small holes in the exhaust downpipe and screwing the temp switch to the pipe with a couple of self tapping screws and threadlock. The place where I intend to fit the switch is above the water line so Im thinking that, even if the screws were to come out, the worst that can happen is a small amount of cooling water leaks into the boat.
Can anyone see any reason why this is a bad idea?
Re: Exhaust alarm fitting?
Ayuh,... I think a Better Question is WHY,..??
Simoniz
Why what?
Why do I want the alarm? To let me know if the supply of cooling water to the engine is interrupted before any damage is done.
Why do I want to drill and screw the sensor onto the exhaust? - To make for a neater more permanant installation and so that there is a better thermal connection between exhaust and sensor.
Ok,.. Then add a Water Pressure gauge...
Exhaust gas Temp senors need to be Dry, not Wet...
Or atleast every 1 I've ever seen...
Simoniz
Thanks, it would have been dry - on the outside of the pipe.
However, I like the idea of a pressure gauge / alarm installation more - thanks Achris, for the link.
