Exhaust baffle question
83vert
I have a thru hull exhaust and from the riser to tip there is a piece of pipe with a bunch of baffles all at different angles. Are they to make the exhaust a little quieter or to stop water from flowing into the motor. The reason I ask is because one pipe is a little crappy and I was going to replace both with a regular piece of exhaust pipe with no baffles.
havasuboatman
Ensign
Re: Exhaust baffle question
Sounds like a muffler to me. Is the pipe diameter significantly larger on the outside compared to the inside?
You can replace that with a piece of straight pipe. Very important that you keep the flappers on the exhaust tips though.
83vert
It seems like the pipe is carboard with fiberglass on the outside. Its wierd I will take a pic.
Ayuh,... It sounds like a muffler,... You still need Flappers/ Shutters, straight or muffled...
