Re: Exhaust Bellow replacement 1984 Mercruiser Alpha
the next thing you need to buy is a repair manual, imho, either a mfg specific or seloc. they have good info and pictures on almost all subjects. you need to give the type engine and outdrive also, but in general, the bellows is usually held on by pipe clamps and glue. it is the easiest of the 3 to replace. but check all three for cracking and leaks. raise outdrive and look around. there are a lot of post and websites on this subject. don't know about cable realignment, do you mean adjustment? again, look for posts and websites. i know what an exhaust manifold is, exhaust elbow is, not sure what the riser part is specifically, someone else will.
