Exhaust coming out below bellow
jjcarroll1
Hi, recently put all new bellows in 1986 3.0 mercruiser alpha 1. Was out in the water and water is bubbling out bout 2" below the exhaust bellow. The bellow itself isn't even under the water so I know it's not leaking there. But it's straight below the bellow 2". Did I forgot something or is something else worn out?
Ayuh,.... There are idle relief ports on each side right about there,.....
Next time ya got the boat on the trailer, look closely, 'n you'll see 'em,....
jjcarroll1
Then what??? Are they replaceable? Or just tighten? Or is it like a seal? Thanks
Scott06
They are holes cast into transom housing so at idle the exhaust doesn’t have to push out 2 ft of water to propeller hub. No adjustment or replacement is needed it’s completely normal
jjcarroll1
Oh ok. But engine sounds loud like a Harley and smells like severe gas fumes.
Scott06
If the exhaust bellows aren’t in water then the boat isn’t in the water …gas fumes are another issue
On the trailer my old boat with a 3.0 was louder than my current boat with a 5.0 the water is the muffler…
