Exhaust Flapper?
aolsen
I have a 2.3Ltr OMC I have been working and the flapper is missing what is the purpose of the Flapper?
Re: Exhaust Flapper?
Ayuh,...
It helps to keep Water from backwashing up the exhaust into the motor, causing Hydro-lock...
chiefalen
The real question is do you need it?
In my own inexpert opinion no.
When you come off plane and to a stop you should let the motor run in neutral for 2-4 minutes anyway. Always.
When you start the motor even warm 2-3 minutes run the boat in neutral, at least 1 minute. I know a minutes a long time, when your looking to move to another fishing spot, or the kids are water skiing and wake boarding.
When running water can't enter the riser.
