FreeBeeTony
- May 15, 2002
- 3,995
After disassembling the water pump in my pre-Alpha I noticed the gasket seemed burned on the bottom side of the plate inbetween the housing and the base. Upon further inspection it appeared there had been exhaust gases in the "watertube side" of the housing. I removed the base and it looked fine underneath. I thought maybe the gases were entering between the base and the lower unit housing but it didn't look like it. I mentioned in another post that the water pocket housing seemed a little distorted. Is this the only other place the gases could enter? I am hoping I stumbled upon a problem and will further improve my cooling.<br /><br /><br />Another problem........when I removed the water pump base I was shocked to see how much growth there was in the water intake under the base! How can this be prevented next year? Anti fouling paint? There appeared to be barnacles in there.........
