I am in the process of replacing the water pump in 69 6hp long shaft. Have the original service manual and have the lu off. The water tube came off with the water pump housing.
Pretty sure I have a problem where the water tube connects to the exhaust housing with a grommet. First of all, the upper end of the tube had what looked like silicone caulk material gooped up on the end of the tube...definitely not grease.
When I look up into the exhaust housing I see a piece of copper tube, the same diameter as the water tube, that is flush where I would have expected the grommet to be. The tube is not out of round like it would be if it had been broken off.
Is the exhaust housing supposed to have the stub of a copper tube attached to it?
It looks like the grommet has deteriorated to the point where it is a hardened mass that is holding the stub of the piece of copper tube in place, but I don't have any experience with outboard repair and this could be the design (although that would leave no place to insert the grommet).
Unfortunately, the manual doesn't show this connection.
Any help would be appreciated.
